Displays a summary of notification log configuration and status, as well as global configuration and status.
This command has no keywords or variables.
Disabled.
Use this command to display a summary of notification log configuration and status, as well as global configuration and status.
The following example displays log configuration and status:
show snmp notification-log
Global Entry Limit  : 10000
System Managed Size : 1500
Global Age Out      : None
Notifications Logged: 2100
Notifications Bumped: 300
Notification Logs   :
Name                      Filter Profile      Flags        Notifications
                                                             Logged      Bumped
default                    all                 EUAP         1500         300
nmslog1                                        EFAV            0           0
nmslog2                    filter1             DMAN          600           0
Flags: Admin Status: (D) Disable, (E) Enabled.
       Oper Status:  (F) No Filter, (M) Admin Disabled, (U) Up.
       Entry Status: (A) Active,   (I) Inactive, (T) Not Ready.
       Storage Type: (N) Non Volatile, (O) Other, (P) Permanent, (R) Read Only,
                     (V) Volatile.
    This command was first available in ExtremeXOS 15.5.
